11-27-2015 05:04 PM
The ZoneFlex AP can also be placed horizontal, i.e., flat-side down, on top of the highest office cubicles .... Wall mounting the AP vertically, i.e., with the dome pointed sideways, should only be done on the “outside” walls as this orientation creates a shadow behind the flat-side of the AP
11-30-2015 10:08 AM
Both recommended mounting methods are for horizontal placement, on a ceiling that would
be dome or top of AP facing down, on a bookcase/shelf that would be dome or top of AP facing
up. Mounting on a wall (vertically) on outside walls, points the most RF energy into the bldg.
You may benefit from refraction to our antenna arrays, so I'd suggest placing the AP flat on
the shelf, 10 feet up and compare connectivity throughout your space, which might be better
than vertically mounted (reaching as far from the "top" of the AP out sideways).
11-30-2015 10:15 AM
