Wireless Mesh setup with r310 and t300
james_wagoner_i
I am trying to see about a presales question about wrieless mesh.  I have setup 2 r310, and one t300 running unleashed.  I would like to take one of the r310 and have it be totally wireless.  I have all 3 setup and working while connected to the LAN.  When I unhook one of the r310, it will never connect up via wireless.  I even tried setting up the zero touch Pre-Approved Zero Touch Mesh.  What am I missing?
10 REPLIES 10
Nikita
Unfortunately R310 does not support mesh
well that would do it...I thought I looked this up good thing this is just in our lab.  Does the r510?
DarrelRhodes
Valued Contributor
Hi James,
As mentioned by Nikita; R310 does not support SmartMesh and neither does R320 (and R300).
You would need to upgrade the AP to R500/R510 to utilise SmartMesh.
HTH,
Darrel.
james_wagoner_i
Thanks all!
Type a product name
