Clients connected on Standalone R710 with NAT/Dhcp have slow wlan performance.
HI.
I have received a report which Clients connected on Standalone R710 with NAT/Dhcp have slow wlan performance.
There are connected about 15 client.
The Ap is connected directly to ISP modem, and served NAT forading Dhcp for wifi-devices.
I connected at AP and found below messages.
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542028] FWLOG: [77571550] vap-0 AP PS: AID=4335968 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542059] FWLOG: [77571550] vap-0 AP PS: AID=4335648 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542059] FWLOG: [77571550] vap-0 AP PS: AID=4335904 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542059] FWLOG: [77571550] vap-0 AP PS: AID=4335712 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542059] FWLOG: [77571550] vap-0 AP PS: AID=4335392 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542090] FWLOG: [77571760] vap-0 AP PS: AID=4336032 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542090] FWLOG: [77571760] vap-0 AP PS: AID=4336160 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542090] FWLOG: [77571760] vap-0 AP PS: AID=4335968 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542153] FWLOG: [77571760] vap-0 AP PS: AID=4335648 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542153] FWLOG: [77571760] vap-0 AP PS: AID=4335904 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542153] FWLOG: [77571760] vap-0 AP PS: AID=4335712 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542153] FWLOG: [77571760] vap-0 AP PS: AID=4335392 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542184] FWLOG: [77571844] vap-0 AP PS: AID=17 detected out-of-sync now=1285531396 tx_waiting=1285521298 txq_depth=13
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542184] FWLOG: [77571970] vap-0 AP PS: AID=4336032 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542215] FWLOG: [77571970] vap-0 AP PS: AID=4335968 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542215] FWLOG: [77571970] vap-0 AP PS: AID=4335648 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542215] FWLOG: [77571970] vap-0 AP PS: AID=4335904 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542215] FWLOG: [77571970] vap-0 AP PS: AID=4335712 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542246] FWLOG: [77571970] vap-0 AP PS: AID=4335392 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542246] FWLOG: [77572284] vap-0 AP PS: AID=4336032 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542246] FWLOG: [77572284] vap-0 AP PS: AID=4335968 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542278] FWLOG: [77572284] vap-0 AP PS: AID=4335456 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542278] FWLOG: [77572284] vap-0 AP PS: AID=4335648 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542278] FWLOG: [77572284] vap-0 AP PS: AID=4335904 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542309] FWLOG: [77572284] vap-0 AP PS: AID=4335712 select next response
Nov 23 07:00:56 500151168650 kern.warn kernel: [5448877.542309] FWLOG: [77572284] vap-0 AP PS: AID=4335392 select next response
What does below mean?
It's shown many.
Regards.
6 REPLIES 6
In addition , The Ap is shown below.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.179704] nf_conntrack: table full, dropping packet.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.179797] nf_conntrack: table full, dropping packet.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.458242] nf_conntrack: table full, dropping packet.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.520660] nf_conntrack: table full, dropping packet.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.623534] nf_conntrack: table full, dropping packet.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.655399] nf_conntrack: table full, dropping packet.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.714380] nf_conntrack: table full, dropping packet.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.757773] nf_conntrack: table full, dropping packet.
Nov 23 08:30:17 500151168650 kern.warn kernel: [5454238.835624] nf_conntrack: table full, dropping packet.
Nov 23 08:30:18 500151168650 kern.warn kernel: [5454238.872612] nf_conntrack: table full, dropping packet.
I know that this is due to poor NAT performance on standalone APs.
Anyone have good idea?
DarrelRhodes
Valued Contributor
Hi Jeronimo,
What version of firmware is your AP using?  If it's the Standalone (100.x.x.x) firmware then either ensure you are on the latest version or I would recommend upgrading to the Unleashed firmware, which is much more feature-rich than the Standalone version.
Thanks,
Darrel.
It.s 104.x.
Have you tried installing the Unleashed firmware, performing a factory-reset, re-configuring and seeing if the fault persists?
Thanks,
Darrel.
