VOIP DHCP Option 43 Not Working | 8090DUFI Code L3
corey_costello
I've got a VOIP phone, and option 43 converted over to hex.
I have verified that everything outside of the ICX is correct, because I can push the options to the phones from another vendor switch using the same hex string and a dhcp server locally on this vendors switch, as well as from another vendors firewall with DHCP, again using the same string.
I have ran pcaps and all the DHCP sequences look identitical, however the phone does not pull it's option from the hex string.
Thoughts?
2 REPLIES 2
BenBeck
It would be very tough to diagnose this over the forum. I would recommend opening a case and having our support group help troubleshoot the issue. Please see my signature for support contact information.
Phone: 855 782 5871
Ben Beck, RCNA, Principal Technical Support Engineer
jijo_panangat
Contributor III
Hi Corey,
This needs a troubleshooting session to identify the problem and a tac case would be appropriate. Pls create one at your earliest convenience.
Jijo
