AP firmware 3.6.0.0.709 High Connection Errors
paul_mcguire_20
Contributor
I have upgraded my Vsz to 3.6.0.0.510 and upgraded the APs to 3.6.0.0.709.  After the upgrade i noticed that almost every AP had a high percentage of connection errors.  I let it go for several days and thought i still had a lot of clients connected so it must be working.  In the events I see a lot of Force DHCP disconnects.  I did not make any changes to that but did double check the settings.  Some wlans were not enabled and some set to anywhere from 5-15 seconds.  Downgraded the firmware to 3.5.1.0.1026 and the connection errors went away.  Has anyone seen this and have any ideas why i am seeing this.
30 REPLIES 30
eightohtwoeleve
Contributor III
No news as of yet, as there hasn't been an update to the original 3.6.0.0.510 release version chain. I suppose the question would be if this fix will be implemented into the next point release or not.
nicola_pastro
i ve a lot of connection failures also with 3.5.1.0.1026
i  don't have any autentications errors, i don't understand what could be the issues.
Tech support told me that is ok, and it s normal... (i don't think).
i tried different configuration but the result was always teh same.
Image_ images_messages_5f91c441135b77e2479ec196_94d553e872e156157ad3b35e3dd08901_RackMultipart201802081310631pd-d9fc6b7e-c62b-4900-97c1-10d0f3c197a1-637509637.png1518079298
Nathan3690
Same thing here. any news on this case ?
nicola_pastro
wow! nice that somebody else is facing these problems! 😄
david_henderson
Contributor II
Any word on when the next level of firmware will be released to fix this issue?
