SCI 3.2 granularity
pamuditha_abeys
Contributor
Hi
Can I select the 3-min, 15-min granularity while setting up SCI or after deployment according to requirement. I don't see any option in installation guide.
Do SCI store data in master node also. If so, shouldn't master and data nodes have same storage?
With 3.2 version, I can have 1+1 setup upto 10000 APs. But with 3.1 version, I need 1+3 setup for 12000 APs. Is this due to 2-way redundancy change in 3.2 or further optimization of application.
6 REPLIES 6
see_ho_ting
Contributor
It's on page 8 of the SCI 3.2 Installation Guide.
Image_ images_messages_5f91c43e135b77e2479dc8cc_ed955a0b487816cc2e973afaa10239ba_RackMultipart20171026645961lzl-adc59db2-717d-4fc7-b57a-5df497ab8664-26460643.png1509032442
pamuditha_abeys
Contributor
Oops. My bad. Thanks a lot.
Type a product name
