12-05-2022 03:32 PM
We've been having inconsistent or slow Wi-Fi in certain rooms (they're at the corners of the house, so not surprising). After troubleshooting, I've decided that adding a Ruckus access point may be a reasonable solution. But in trying that, I've encountered some hurdles and am hoping someone in the community or Ruckus could offer advice.
Thanks!
Kaz
12-06-2022 04:21 AM
Hi @kaz
Hope you are doing well !
1- Did you have a blackout or a power surge at your home?
2-Here are the defaults credentials for Lennar home users :
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users
3- When connecting the New access Points R650 are your seeing any light on ? which one ?
Here is the meaning of each light on the Wireless Access Point
4-On the sticker of the R650 does it say unleashed or zone flex?
Best Regards
Fernando Vasquez
12-07-2022 10:39 AM
Hi Fernando,
12-07-2022 11:33 AM
Hi @kaz
2-From the unleashed mobile app or unleashed management dashboard :
Here are some Videos 'Demo'
https://www.youtube.com/watch?v=L_oAReVK1qo
https://www.youtube.com/watch?v=z4zbJcBSuuw&t=14s
2-Is this a reseller, that is, a second-hand item?
3-Seems to be strange must of the times there is a sticker with the Serial/Mac and it says unleashed or zone flex version.
4-It could be several reasons like PoE settings /Speed settings on the ports also if the test cable is a well know cable
Speed :
PoE
Best Regards
Fernando Vasquez
12-07-2022 12:44 PM
Hi Fernando,
The R650 should be a new item (not second-hand). On the seller's page on Amazon, it says that "This is the exact same hardware as the Unleashed model - but with different firmware." Is it important that I update the firmware to Unleashed?
Videos seem to assume that some Ruckus device is set to 192.168.0.1. For my setup, my COX modem is set to that address, and the 7150 is connected to that COX modem. Does this change what I need to do?
