01-16-2024 11:05 AM - edited 01-16-2024 11:06 AM
Icx7150 switch stuck in router mode. Will not connect access ports. Need a replacement.
01-16-2024 12:59 PM
Hi @Cg44150
Apologies, this is very simple issue to troubleshoot and it’s a software issue that can be easily fixed by following the guide. As per our policies warranty is not covered on the software issues.
Please do not use the Unleashed application to check the IP Address. You can find the IP Address of the Switch using the IP Scanner on the laptop and troubleshoot the issue on the laptop itself.
Please follow the Routing Code troubleshooting guide step-by-step and let me know if you are stuck at any point during the process.
01-16-2024 01:13 PM
I only have a Mac and not a pc
01-17-2024 04:48 AM
Hi @Cg44150
If you have a MAC device, please refer to the below guide and access the CLI to execute the commands to resolve Routing code issue.
Please follow the above guide and let me know if you are stuck at any point.
Thank you again for your understanding.
04-04-2024 07:36 PM
Hi Imran,
I have the same issue as the original poster. I was able to get on the CLI via putty, but the commands that I'm putting in as instructed are not being recognized by the system .What should I do? Thanks
04-05-2024 05:31 AM
Hi @dkiang1
Hope you are doing well
As this case is raised by @Cg44150 it is now closed.
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly. Please raise a new post with the above description on RUCKUS Lennar Support
