07-07-2024 01:54 PM
Hi there,
I own a Lennar home and we have a Ruckus ICX 7150-C12p and it suddenly stopped working- does not look like it has power. I have tried it in different outlets, and tried doing a factory reset over 20 times. When I do the factory reset all the lights flash once yellow and then go out. Even if I continue holding the reset button the lights don’t come back on. I have also tried to do the reset using a computer (found the instructions from another forum question)and no luck. Only one of the three websites that are given work. Please help! Thank you!
07-08-2024 03:10 PM
I have figured it out. Please let me know you have received it. Thank you.
07-09-2024 05:23 AM
Hi @kristenrwillis
Thank you for the response and the Video.
Could you please confirm, once the Switch is plugged to a working power outlet does all LEDs blink amber for a moment and goes dark?
If yes, please share a video of the same.
07-09-2024 06:56 AM
Yes, once plugged into power the yellow lights blink once then go dark and no other lights appear. A video has been uploaded via the link you sent previously.
thank you
kristen
07-09-2024 07:27 AM
Hi @kristenrwillis
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. Even tried hard reset. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
07-09-2024 07:38 AM
Thank you so much for your assistance. When should I expect this to be replaced and will someone come out to set it up?
