07-25-2023 12:44 PM
Hi. This ICX cannot be managed by unleashed network, because "super-user-password" is enabled on it. please disable "super-user-password" and try again. Is the message I received when trying to connect switch in unleashed .Switch is a ICX7150-C12 . Access point 510. I know the ip address and can connect to configuration page with user name and password.Also can access through putty. Thanks
07-25-2023 12:57 PM
Hi @tc6string
Hope you are doing well!!!
As per the case description, I could understand that you are unable to access RUCKUS ICX-7150-C12P Switch on the Unleashed and there is an error.
Could you please share the screenshot of the error “super-user-password” you are getting?
Also, as you mentioned that you can access Switch CLI via Putty, please share the output of the below commands.
show version
show flash
Please share the output of the above commands and let me know if you have any queries in this regard.
07-25-2023 06:03 PM
Hi. Here are the screenshots.When type the command enable I get prompted for a password.I was actually connected to the switch before hand until I updated firmware. Once I updated the firmware it switch to router mode and the internet connection was lost. I actually flashed to the secondary and it went back into switch mode and where I’m at now
07-26-2023 08:05 AM
Hi @tc6string
Could you please share the output of the commands shared in my previous post? If MobaXterm is not working for you, please try using Putty Application.
07-27-2023 03:50 PM - edited 07-27-2023 03:51 PM
Hello. Same results . Don’t know the password after enable. Thanks
