07-24-2024 05:35 AM
Lennar home user. Never had any issues with my switch and access points for five years. Appears switch is suddenly failing. Ports will power off after a couple minutes every time I try to reboot. The switch box is also pretty hot. I think its.dying. help!!!!
07-25-2024 08:58 AM
Thanks for the explanation; that does make sense. Honestly, I really don't have the time or expertise to upgrade firmware/software myself on complicated network switches. Is there some way we could schedule a technician to come out? Many thanks
07-25-2024 09:05 AM
Hi @llfreedman
Please check your private texts for further steps and reply there itself. (Refer to the below screenshot- it will be at right top corner on the this website portal)
Thank you again.
07-30-2024 05:37 AM
Hi @llfreedman
I kindly request an update on the status of the issue on the private Chat so that we may proceed further with resolving it. Please refer to my previous post.
Thank you.
08-01-2024 07:16 AM
Hi @llfreedman
Thank you.
08-01-2024 07:24 AM
I don't see any private messages. The mailbox icon is not there.
