Ruckus wont re-boot -- Need Replacement
hdifrancisco
My system is not working.  I have rebooted, plugged in a different outlet and still no connection.
Its now 2 weeks...I need a new router and no one at RUCKUS =LENNAR SUPPORT seems to want to acknowledge.
1 REPLY 1
Imran_ruckus
Community Manager
Community Manager
Hi @hdifrancisco
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not working.
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Please let me know the answer to the above query and let me know if you have any queries in this regard.
