Ruckus system not working
smriti
Ruckus Switch LightsRuckus Switch LightsTwo weeks back I got a firmware update in Ruckus Unleashed and after that, the APs are not getting connected.
I tried to restart the device and reset the device, but nothing seems to be working.
I am not able to connect any computer/mobile device to the Ruckus Unleashed wireless network.
Both the main and secondary device have green lights on it.
3 REPLIES 3
Imran_ruckus
Hi @smriti
Hope you are doing well!!!
From the case description, I could understand that you are unable to connect with the Unleashed wireless network through the RUCKUS Access Points after Upgrading them.
May I know how many Access Points are connected to your ICX-7150-C12P Switch? If you have more than one Access Point, please check if all the Access Points are upgraded to the same version. All must be Upgraded to the same version. Please refer to the below screenshot as an example.
Please check and confirm and let me know if you have any queries in this regard.
We cant even connect to the unleashed. Its not getting connected using the usual username and password. So how can i check all two access points are upgraded to the same version.
Hi @smriti
Please try to use the default combination credentials as mentioned in the link below to login into Unleashed.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Admin-usernames-and-password...
