10-17-2023 02:35 PM
Home built in 2019. Ruckus only controls the ring doorbell camera in the house. Every other day the ruckus shuts off, therefore shutting off the ring doorbell. We are able to reboot the ruckus but what could be causing the ruckus to consistently turn off?
11-20-2023 08:04 AM
Hi @Chelskylar
Are you able to see the IP Address of the RUCKUS ICX-7150-C12P Switch from the IP Scanner application?
Please check the other IP Addresses from the IP scan results, by the name of Ruckus Wireless or Brocade Communications to confirm the IP address of the Switch and access the CLI.
12-02-2023 07:53 AM - edited 12-02-2023 07:54 AM
Hello Imran,
Please see the screenshots below.
12-04-2023 07:23 AM
Hi @Chelskylar
Could you please confirm if you are using the correct Switch IP Address? Are you able to see the Switch dashboard on a web browser as described in my previous post?
Please confirm and let me know if you have any queries in this regard.
10-19-2023 06:47 AM
The same issue this user has described is happening to me as well. However, my RUCKUS device controls more than just the ring doorbell. Every couple days the RUCKUS device loses power, but if I unplug and plug back in, lights return and everything is on/back to normal.
Assuming I'll receive the same canned response to provide images, I will do this later today
10-19-2023 08:21 AM
Hi @kdaytime
Hope you are doing well
As this case is raised by @Chelskylar
To avoid confusion with posts, you can create your own post with the above description of the network issue and what you've done so that we can guide you properly.
