07-17-2023 09:24 AM
My Ruckus is not powering up, I have tried all suggested fixes stated in previous inquiries for the same issue. I am needing to get ours replaced and can only do so via this forum.
07-17-2023 10:13 AM
Hi @noakes
Hope you are doing well!!!
As per the case description, I could understand that your ICX-7150-C12P Switch is not powering up.
We will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
04-19-2024 03:21 PM
I am having the same issue and have tried MULTIPLE times and am in need of a replacement
04-22-2024 05:56 AM
Hi @MLedesma
As this case was raised by @noakes which is old and now closed.
Please raise a new post with a detailed description of your network issue on RUCKUS Lennar Support
Thank you again for your understanding.
