Ruckus ICX 7150-C12P not booting up after a power outage
dang7602
My ruckus system is not powering up, it flashes the lights for a second then nothing. This is a ICS7150. I have already tried multiple attempts to reboot the device but nothing seems to be working.  Please help me resolve this.
7 REPLIES 7
Imran_ruckus
Community Manager
Community Manager
Hi @dang7602
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not booting up after a power outage.
Could you please try to reset the Switch as explained in the below VIDEO:
As you mentioned that you tried reset, once again we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
Video link: https://www.youtube.com/watch?v=6jHMTdo_hK4
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Please check and let me know.
dang7602
Followed the above and it still does not work properly.  What do I do now?
Hi @dang7602
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and a VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet? Please refer to the below pictures as an example.
dang7602
It's uploaded, video (20231220_132133) and a photo (20231220_132432)
