Showing results forย
Search instead forย
Did you mean:ย
Ruckus ICX 7150-C12P No Power
Anhdinh
Flashes of Orange lights, then nothing, no lights, no signs of life. I tried different power cords, and outlets but same result.  Please help.
6 REPLIES 6
Hi Imran,
The video is uploaded. I did not have a power indicator on hand, so I used a portable lamp to show that the plug had power.
Hi @Anhdinh
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
