Ruckus APs and Switch Disconnected
rajamadupu
We recently had a power outage near our house which seemed to have disconnected our switch and APs. I know this because I logged into the Ruckus Unleashed website and saw disconnections for both. After going through hours of troubleshooting, I've found that 1) My switch is NOT in boot mode and 2) There is not a Routing Code issue for the switch (it shows SSH@ICX7150-C12 Switch> on the CLI). Are there any solutions for this?
4 REPLIES 4
pinky_ruckus
Valued Contributor III
Hi @rajamadupu ,
As per the case description, I understand that your Access points are no longer turning on after the power outage.
1)  On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
2) May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
pinky_ruckus
Hello @rajamadupu ,
pinky_ruckus
Hello @rajamadupu ,
pinky_ruckus
Hi @rajamadupu
Thank you.
