Re: Ruckus ICX 7150-C12P doesn't turn on (No power, no status light)
dvrasco19
I am having the same issues of my ICX-7150-C12P not powering on.
I Already tried different power cords/outlets, but no luck. Also tried the reset instructions below, no work either. Please help.
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
What other information do you need?
5 REPLIES 5
dvrasco19
Hi @dvrasco19
I hope this message finds you well. We appreciate the information you provided regarding your RUCKUS ICX-7150-C12P Switch not powering on.
To proceed with resolving the issue with your ICX-7150-C12P Switch, we kindly request that you follow the steps outlined below:
1. Plug your ICX-7150-C12P Switch into a functioning power outlet.
Hi @dvrasco19
Your prompt response would be greatly appreciated.
Thank you for your attention to this matter.
Hi @dvrasco19
Type a product name
