03-30-2026 06:10 AM
I have received an E510 to extend the WIFI coverage outdoors. In addition to a power supply, the documentation indicates that I must also purchase an antenna module. Is this absolutely necessary or could I just add short antennas to the 2 antenna ports? It seems that the antenna module may be needed only if adding cables to run to a more remotely located antenna. Thanks in advance for your assistance.
03-30-2026 07:33 AM
Hi @MizzouWoman
Thank you for contacting RUCKUS Community Support forums.
The Ruckus E510 is a bit unique compared to typical APs, so the confusion is totally understandable.
The E510 uses a split architecture:
This design is intentional to allow flexible deployment (Ex: hiding the AP inside enclosures while placing the antenna externally for better signal propagation).
Yes, in most cases, it is required.
Those ports are used to:
They are not intended for generic dipole antennas, and using such antennas:
If you have the E510 AP without the antenna module, best next step is to procure the official antenna module (902-2101-xxxx) to ensure proper operation.
If you run into any issues during setup or need help validating the deployment, I would recommend raising a support ticket with RUCKUS Tech Support for deeper assistance using link below:
https://support.ruckuswireless.com/
Hope that helps.
RUCKUS | Community Forums Support
