10-19-2024 02:44 PM
Why is my internet speed so slow with a Cat-5/6 cable from the Ruckus switch to my access point, even though I get Gig speeds directly from my ATT router using a Cat-7 wire? My Spotify streaming drops to just 25Mbps. Could it be a setup issue with the switch or cables? Any installation guide or suggestions for upgrading the switch and access point?
10-21-2024 05:30 AM
Hi @enzo5
Based on the information provided, it appears that you are encountering intermittent internet connectivity.
4. How many access points are currently connected to the switch? Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
10-23-2024 05:23 AM
Hi @enzo5
Thank you.
10-25-2024 05:13 AM
Hi @enzo5
Thank you.
10-28-2024 09:11 AM
Hi @enzo5
Thank you.
