05-17-2024 06:30 AM
ICX 7150-c12p: system an power light green
qty 2: R510 Access Point
We had a power outage last night and the r510 no longer have any lights coming on.
I rebooted the entire system: no change
Reset the r510 and nothing
Before concluding the access points are bad, I want to make sure there isn't more I could check. Both going out at the same time makes me think they got fried.
05-17-2024 09:51 AM
Hi @this14linda
Please try to reset the Switch as described in the below VIDEO then try to IP scan once again.
VIDEO link: https://www.youtube.com/watch?v=6jHMTdo_hK4
05-17-2024 10:59 AM
Do you have any suggested repair services that deal with your equipment. This is way out of my expertise and I have already spent 6 hours on it. Any direction you can point me would be greatly appreciated!
05-17-2024 11:20 AM
Hi @this14linda
Apologies for the inconvenience. This forum is on best best-effort support basis.
Regrettably, RUCKUS does not provide on-site technical support for Lennar Homes. We recommend attempting a hard reset of the switch as outlined in my previous message and rechecking the IP scan. Occasionally, after a reset, access points may also receive power.
Additionally, could you kindly confirm whether you have access to a Windows laptop?
05-17-2024 11:55 AM
I can confirm no access to anything windows. The video said that if I do a reset, everthing will need to be reconfigured, I think that is way out of my comfort level.
05-17-2024 12:07 PM
Hi @this14linda
Please note, there is no configuration required only need to reset the Switch using paper clip.
Please refer to the below guide and VIDEO:
Please let me know if you need any help during the process.
