PS5, Phones, TV, Computers not staying connected to network
trevor
WiFi Network shows up fine and works with Speed Test.  Everything will connect but then shows failed or errors.  I got a DNS server error on my PS5.  Phones and everything else don’t show an error but won’t access internet, download, nothing.  I messed with the IP address a while ago using directions from another thread and it didn’t work.  I’m not computer savvy enough to do the software recovery.  Need help.
15 REPLIES 15
Hi @trevor
As per the light state, they are in a normal state.
However, based on the picture you shared, it appears that the black cable from your Internet Service Provider’s (ISP) router is connected to the incorrect port on the RUCKUS ICX-7150-C12P Switch. The cable should be connected to one of the 1-12 ports on the switch (please refer to the screenshots below). Kindly unplug the cable and reconnect it to the appropriate port. Afterward, please reboot the ISP (Internet Service Provider) router by unplugging and plugging it back into the power outlet. Once done, unplug/plug the APs from the Switch ports and check your internet connection after some time.
Please let me know how it goes, and feel free to reach out if further assistance is needed.
Hi Imran,
I followed your instructions exactly.  It worked for a minute and then returned to the same connectivity issues.  Sites will load and then stop loading.  VPN won't connect.  Same issues as we started the thread with.  Let me know what's next please.
Hi @trevor
Apologies for the inconvenience.
To check the details, please execute the following commands in the CLI and provide the outputs:
   show version
   show flash
   show inline power
   show inline power detail
   show interface brief
Hi @trevor
I kindly request an update on the status of the issue so that we may proceed further with resolving it. Please help with the requested command outputs from my previous post.
Thank you.
Hi Imran,
I feel like I’ve jumped through enough hoops.  Who do I speak to in order to get a replacement due to the known defect that Ruckus knew about and failed to address during the warranty period?
Type a product name
