06-14-2023 04:56 PM
My internet connection keeps dropping in my home. Things will not connect to my network then it will or it will go offline. Need help .
06-15-2023 09:29 AM
I’m done. It’s not working this is a waste of time and nothin solves the issue. How can we not have a customer support line. We have to just email. This is the worse.
06-15-2023 01:26 PM
Hi @Scipe11
If you are unable to get the IP Address of the Switch, we must try getting console Access to the Switch as described below.
If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case, we need a USB type C to USB standard or Console cable Rj45 to USB.
06-15-2023 09:18 AM
Can someone just call me
06-15-2023 09:24 AM
Hi @Scipe11
Apologies, effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email. We will be exclusively supporting customers via this community forum support model only.
Please add ‘ssh’ at the beginning of the commands and check other options as mentioned in my previous post.
And make you to confirm if you are using the correct IP Address of the Switch.
