My ruckus switch stuck with amber lighting after power fluctuations
rahulmandava
Recently there was multiple power outages back to back since then my ruckus switch isn’t working, it has power but sys label is stuck with amber light. None of my access points are powering up either since then. As I found here in the forum, I tried resetting many times by using reset button and simultaneously plugging the power, but it didn’t work. Now I learned it might failed to reboot and corrupted and I need to reinstall image or something of that nature. But I am unclear on how to do that by consoling from my laptop into switch? Or if the problem doesn’t require reinstalling image but something else? Any help here is greatly appreciated as I am stuck and switch isn’t working from last few weeks.
4 REPLIES 4
Imran_ruckus
Community Manager
Community Manager
Hi @rahulmandava
Based on the information provided, it appears that your RUCKUS ICX-7150-C12P Switch is stuck in boot mode with Amber SYST LED.
If multiple physical hard resets do not resolve the issue, the next step is to perform the Software Recovery process.
Please refer to the following RUCKUS Lennar Knowledge Base self-help article for the complete recovery procedure:
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Fixing-RUCKUS-Switch-with-an...
Kindly let me know how it goes. If you encounter any difficulty or get stuck at any step during the Software Recovery process, I will be happy to assist you further.
Imran_ruckus
Community Manager
Community Manager
Hi @rahulmandava
Thank you.
Imran_ruckus
Community Manager
Community Manager
Hi @rahulmandava
Thank you.
Hi Imran, Sorry for the delayed response. Yes I did try the steps. But unfortunately after setting and saving new environment, when I test with ping I get timeout and not alive status. I disabled my windows firewall, reconnected usb between switch and laptop, but it still didn't work. Not sure what is wrong, could you please assist me to get pass this step? I used Type C to USB connector between switch and my laptop.
