06-23-2023 04:05 PM
We lost power both APs aren’t receiving power after power returned. I have Reset all items several times APs and switch. I have switched cables where possible. I have attempted reboot using coms port that didn’t accept a boot load, flash attempted but failed. Boot said invalid. Not sure what I could do here.
06-23-2023 04:06 PM
I see other post yet the switch will receive software flash.
06-23-2023 04:07 PM
That is will not receive sorry that’s a typo
06-23-2023 04:35 PM
Hi @akalala
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points are not powering up.
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the cable connections to the Switch ports)
2. May I know total how many Access Points are connected to the Switch?
06-25-2023 06:12 AM
