05-26-2021 12:49 PM
I have a Lennar House that came installed the ICX-7150 and two R510s. I've been having issues with the APs resetting periodically that I thought I resolved by repairing a bad ethernet connection, but seems there might be more to it. Last night I upgraded my ICX to unleashed, and am seeing that the connection to the ICX drops almost exactly every four hours, which is an improvement over what I had with the bad ethernet cable but still a problem because my APs drop until it comes back online. I have an edgerouter-x managing DHCP but otherwise a pretty straightforward setup. Any thoughts on what my be causing this?
Appreciate the help in advance!
2021/05/26 15:16:34
High
ICX [d4:c1:9e:20:cf:15] joins.
2021/05/26 15:15:37
High
Remove ICX config [logging host 192.168.4.135 udp-port 6514], it will block Unleashed AP to manage ICX.
2021/05/26 15:14:52
High
Lost contact with ICX [d4:c1:9e:20:cf:15].
2021/05/26 11:16:43
High
2021/05/26 11:15:45
High
Remove ICX config [logging host 192.168.4.134 udp-port 6514], it will block Unleashed AP to manage ICX.
2021/05/26 11:15:00
High
2021/05/26 07:15:58
High
2021/05/26 07:15:01
High
Remove ICX config [logging host 192.168.4.133 udp-port 6514], it will block Unleashed AP to manage ICX.
2021/05/26 07:14:15
High
2021/05/26 03:16:45
High
07-30-2023 07:46 PM
I also live in a new Lennar home 2020 that came with a Ruckus ICX switch and 3 APs. Started having some wifi issues and noticed I'm getting the same log messages,
Remove ICX config [logging host x.x.x.x udp-port 6514], it will block Unleashed AP to manage ICX.
I'll try the firmware upgrades.
What ended up being the solution to this problem?
