07-14-2023 01:13 PM
We recently rented a home with a Ruckless Wireless system and want to set up for our use. We have gone online but haven't been able to do this ourselves and need assistance.
07-14-2023 01:24 PM
Hi @twmiller41
Hope you are doing well!!!
As per the case description, I could understand that you need assistance in setting up your RUCKUS Devices.
Please refer to the short guide link below about how to connect the devices as reference:
Please check, confirm the device connectivity as per above pictures and guide explanation. And let me know if you have any queries in this regard.
07-14-2023 03:35 PM
We have everything connected but not getting any service to the extenders. One light on Ruckus box is yellow and no lights on the extenders. Am I supposed to be on my Cox network or something else? There are labels on the panel for Lennar but nothing matches a network that shows up. I also tried the configure me network like described in the start guide but no internet service.
07-14-2023 03:39 PM
Hi @twmiller41
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
07-14-2023 03:59 PM
Amber light for SYST. Green lights for Power and Update.
Cox Cable internet is working fine.
Two access points connected. No lights on at all for either.
