192.168.0.2 is not alive and Switch in boot mode after power outage
sonia3187
My power flickered and since then the Switch - ICX 7150 hasn't started. The amber light is on and when I attempt recovery by following the steps suggested in this post - https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-re..., I am getting the error as shown in the screenshot below -
My windows firewall is also turned off.
Please assist. Thanks!
4 REPLIES 4
Imran_ruckus
Hi @sonia3187
Thank you for reaching out to the RUCKUS Lennar Home Community.
Based on the information provided, it appears that you are encountering issues during the RUCKUS ICX-7150-C12P Switch Software Recovery process.
Please check the following:
1. Please ensure that you are using both an Ethernet cable (with RJ45 connectors on both ends) and a USB to Type-C cable, as outlined in steps 2 and 3 of the provided guide. For your reference, I have included a screenshot below.
2. If you encounter the same issue after connecting both cables and disabling the firewall, please reboot your laptop and the RUCKUS switch and retry the Software Recovery process again.
3. Should the problem persist, proceed with the remaining commands following the "ping not alive" error message. Please check if the SYST LED turns green after completing this process.
I appreciate your attention to these steps and look forward to your feedback regarding the output.
Should you have any questions, please do not hesitate to reach out.
Imran_ruckus
Hi @sonia3187
Thank you.
Imran_ruckus
Hi @sonia3187
Thank you.
Imran_ruckus
Hi @sonia3187
Thank you.
