Ruckus Cloud DHCP POOL problem
winghung
I would like to use Ruckus Cloud (R1) with the DHCP POOL service the assign existing IP subnet which it connection lost between the gateway and internet.
Is it NAT problem or DHCP pool configure wrong ?
there are testing case:
Case 1 - Result: Successful
local DHCP server <-------> POE Switch <----------> Ruckus AP R550
local DHCP assign subnet 192.168.10.x/27
POE Switch: VLAN 1, 110, 120 untag
SSID: default VLAN 1
Case 2 - Result: no Successful & cannot access internet & default gateway
local DHCP server: no assign the IP
SSID: VLAN 120
Ruckus AP - DHCP POOL: 192.168.10.x/27 & VLAN 120
Case 3 - Result: Successful, can access internal & gateway
SSID: VLAN 110
Ruckus AP - DHCP POOL: 192.168.0.0/27 & VLAN 110
0 REPLIES 0
