Ruckus ZoneDirecto
Oliver
hey team If you have any suggestions on how I can reset my Ruckus ZoneDirector password or figure out how to crack it, please let me know.
1 REPLY 1
vijaykuniyal
RUCKUS Team Member
Hi @Oliver,
ZD password can be recovered only:
  • If we have a ZD debug or back up file which was taken out after changing the password, then from  those files support team can extract the username and password for you with a support case.
  • You can only reset an existing ZD password from a ReadWrite(RW) SNMP string.
    If you have details of the write SNMP community string available and a SNMP server which can be used to set new admin password, commands on SNMP server.
  • snmpset -v 2c -c SNMPSTRING <DEVICEIP> <OBJECTNAME/OID> s "abcd" {For string}
    e.g. (to change password to string test)
    root@SNMPSERVER:~# snmpset -v 2c -c Write123 10.1.1.1 .1.3.6.1.4.1.25053.1.2.1.1.1.1.26.0 s "test"
SNMP MIB ref: https://support.ruckuswireless.com/articles/000004433
If we do not have information on SNMP, any such files from the ZD then the only way is to hard reset the ZD
Vijay Kuniyal
Staff Technical Support Engineer
CCNA RnS | CCNA Wireless | CWNA | RASZA | Meraki CMNO | RACPA
