04-09-2021 01:19 PM
Hi All,
I'm having a difficult time locating this specific firmware rev that we're using in our environment:
(ver 08.0.70aT213)
We have some legacy deployments that use ICX 7450 switches where we wish to use this firmware until we are ready to roll them up.
Is it possible to get a hold of this still?
Thank you!
Mike
04-09-2021 03:50 PM
Hi Michael,
It is 08070 code and has been un-published due to not fixable defect.
You should get the latest version of code and should be able to use the same config.
It has a lots of defects that were in 8090 and prior releases.
Please download 08090h code from here:
https://support.ruckuswireless.com/software/2806-ruckus-icx-fastiron-08-0-70h-software-release-zip
Hope this helps.
Hashim
04-09-2021 01:22 PM
You should be able to find it. If not, download it off of a device, validate its checksum, and then send it to other switches.
Best regard,
Justin
04-09-2021 03:50 PM
Hi Michael,
Hope this helps.
Hashim
