tinkering with vxlan
Nate
i am trying to tinker with vxlan settings, and following this article: https://docs.commscope.com/bundle/fastiron-09010-l2guide/page/GUID-68DD54AE-D4CA-4102-BA43-FA860C7B3...
am stumbling at the start -- the 'overlay-gateway' command seems to be missing on both of these icx7150 switches i'm using in my lab.  using SPR09010j
ICX7150-24P Router#sh ver
UNIT 1: compiled on Jan 12 2024 at 09:59:12 labeled as SPR09010j
(33554432 bytes) from Primary SPR09010j.bin (UFI)
SW: Version 09.0.10jT213
Compressed Primary Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compiled on Tue Nov 29 12:43:26 2022
HW: Stackable ICX7150-24-POE
UNIT 1: SL 1: ICX7150-24P-4X1G POE 24-port Management Module
Serial #:
Software Package: ICX7150_L3_SOFT_PACKAGE
Current License: 4X10GR
UNIT 1: SL 3: ICX7150-4X10GF 4-port 40G Module
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
STACKID 1 system uptime is 56 minute(s) 44 second(s)
The system started at 09:58:51 GMT+00 Fri Jan 12 2024
ICX7150-24P Router#conf t
ICX7150-24P Router(config)#over
Unrecognized command
Invalid input ->over
Type ? for a list
Node doesn't exist
1 ACCEPTED SOLUTION
Vásquez_Fer
Hello @Nate  ,
Hope you are doing well ,
VxLAN is only supported on the following platform
Best Regards
Fernando Vasquez
1 REPLY 1
Vásquez_Fer
Hello @Nate  ,
Best Regards
Fernando Vasquez
