04-17-2023 07:05 AM
Hi Pack,
I need to monitor 4 servers and 2 firewall/routers, what makes 8 seperate ports (SFP+, 10G each) for the server hosts and 2 LACP with 2x 10G SFP+ per LACP for the firewalls > so I need to monitor 12x 10G ports. These 12 ports are divided over 2x ICX 7650-48F switches that make 1 stack.
I'm unable to make this work because I think I can only use 8 egress ports for all members in the stack? Port Mirroring and Monitoring Configuration (commscope.com),
I see 20x egress monitored port but in the note I read 8. When I try to add a 9th port I get an error. I also tried to work with 2 different mirror ports (1 on each unit of the stack, because 2 on the same stack is not supported), but the limit of 8 ports is for both added. So I'm still unable to monitor more then 8 ports, the switch counts all ports together even when divided over 2 mirror ports).
Before we used the new Ruckus ICX7650 stack, the core switch was a HPE 5700 stack and I was able to make 2 mirrors with all these ports.
Anyone any idea how I can fix this?
thanks!
