09-20-2024 01:37 PM
trying to update firmware on ICX7750-48XGF 48-port Management Module that are in a stack of x2.
it reboots put only shows up on stack unit 2 as primary code.
| Stack unit 1: |
| Compressed Pri Code size = 27592442, Version:08.0.95gT201 (SWS08095g.bin) |
| Compressed Sec Code size = 27592442, Version:08.0.95gT201 (SWS08095g.bin) |
| Compressed Pri Boot Code size = 1835520, Version:10.1.19T205 (swz10119) |
| Compressed Sec Boot Code size = 1835520, Version:10.1.19T205 (swz10119) |
| Code Flash Free Space = 675971072 |
| Stack unit 2: |
| Compressed Pri Code size = 27442729, Version:08.0.95pT201 (SWS08095p.bin) |
| Code Flash Free Space = 718274560 |
Do I need to go to J then to P?
thanks
10-02-2024 09:29 AM
Hi RandomAK
Thank you for reaching us
Could you please clarify the versions you are trying to upgrade from and to? You mentioned upgrading from version J to P, but the flash output indicates that the common version in the secondary is G.
Additionally, could you provide more details about the issue you are encountering during the upgrade ? Also please help us with "show version" output.
