enable web management
I apologize for the simple questions, but just inherited a
large campus network with numerous ICX switches that is basically a large dumpster fire.
Until I can get up to speed on the IOS, I want to enable Web management without the risk of causing any issues.
 I can ssh just fine into the switch.
Changed “no web-management http” to “web-management http”, but can’t log in.
I assume I need to add:  “aaa authentication web-server default local”
Just want to confirm that?
Thanks again & I really appreciate any response.
Cheers!
6 REPLIES 6
I'm new to Ruckus as well and have used the follwoing commands on to begin configuring 5 Ruckus switches that a new client needs configured.
Below are commands that helped me get to the web interface. The switch needs an IP Address to gain access to the web interface.
hostname Main1_7150_C48P_ZP
enable super-user-password [ password ]
no enable super-user-password [ password ]
(Only for Layer 3 Router)
interface ethernet 1/1/47 (You choose the interface, Possibly the management Interface)
ip address 192.168.X.5 255.255.255.0
write memory
(For Layer 2 Switch)
ip default-gateway 192.168.X.1
write memory
To gain access to the web interface
crypto-ssl certificate generate
username [ username ] password [ password ]
write memory
These are good.  It is a lot easier to configure via the CLI though to be honest.
On the Layer-3 firmware, most IPs will go on the VE's or a loopback for routing protocols.  The VEs are the VRIs (Virtual Router Interfaces), and are referred to as SVIs(Software Virtual Interfaces) on Cisco.
i.e. int ve 123 on the Ruckus vs int vlan 123 on a Cisco.
Other than that, you have untagged interfaces under a VLAN to assign access ports. If you use the TAGGED keyword under vlan and add interfaces, they are 802.1q trunk ports (i.e. same as dot1q on Cisco).  If you have both, the vlan an interface is untagged within serves as its native vlan, which used to be referred to as dual-mode if you see older documentation.
Hope that helps.
Hope that helps.
