When I add a second port to a existing LAG it is immediately disabled, why?
michael_ridenou
Link aggregation issue
Everything appears to be correctly configured for some reason upon addition of the secondary port to the LAG it disables. I have tried everything short of completely eliminating the lag and reconfiguration but would like to avoid that if at all possible.
6 REPLIES 6
Reeegman
Internal Employee
Not sure if I can help.....however it might help if you identify the Product\model type you are referring to.......the version of code\OS that you are running on the platform and device is on the other end of that LAG.
michael_ridenou
Source
ICX7750-48XGF
SW: Version 08.0.70cT203
Receiving
ICX7450
SW: Version 08.0.30rT211
jijo_panangat
Internal Employee
Hi Michael,
Well, Not sure it detects a potential loop, Do u see any error message when lag is disabled ?
Jijo
I do not see anything on the log that pertains to either of the ports int he LAG
