Switch not getting configuration from SmartZone
jason_hilt
We are using a SmartZone 100 to manage our APs and are now installing ICX 7650 switches to run multi-gig APs.  These are the first Ruckus switches we have and I am having issues with them getting the configuration from the SZ.
SZ is on version 5.2.1.0.515
Switch version is TNS08095a
I have setup switch groups and configured DNS, AAA and the management vlan and normal port vlans for the switches that are put in the group by switch registration rules, which works.
I can not figure out how to get the configuration applied to the switch when it connects to the SZ and is put in the group.  I have factory reset the switch and only put in the IP, gateway, and the manager active-list.  I get the "Welcome to SmartZone 100" message but then that's it.  The configuration from the SZ never gets applied, even after reboots.
I read that the group configuration will not be applied if there is a configuration on the switch, which is why I factory reset it.
What needs to be done so the switches will get the configuration from the SZ without me going in and editing each and every vlan on all the groups after the switches have joined?  Is there a way to 'push' the configuration to the switch?
1 REPLY 1
jason_hilt
So I thought I had it figured out....
Update switch to latest OS, but DONT do a WR ME.  Just do a reboot when needed.
Enter only IP address, gateway and sz active-list.
Controller found switch and applied the group configuration, somewhat.  Group configuration on some switches is different from the individual switch configuration, even though no other configuration was done at the switch level.
I've also ran into a new problem where if the main uplink is disabled on the downstream switch or the SFP is removed/inserted on the Ruckus switch, the port on the Ruckus switch will not come back up without doing a full reboot.
I am about to just ditch using the SmartZone to control the switches as it doesn't seem to work correctly.
Anyone have any ideas on what the issue is?
Type a product name
