08-06-2021 03:38 AM
I am configuring two switches a 24P and 8port. The 8 port is to have two access points on it and the 24P will have have the rest of the network hanging off it.
I have set the ip address of the switch to (for example) 192.168.x.x 255.255.255.0, on CISCO this normally set the management vlan but on the IC it is not setting the management Ip address? What am I doing wrong
Also, when I set the two swithes in series do I need to configure a trunk like CISCO or not?
This is abit different to CISCO so looking for a bit of help and guidance so as to avoid install issues and network loops with two switches
Thanks all
