Switch Issues
sjanik
One of my AP's on my switch (port2) is currently only showing speed on 100 mbps instead of the 1.0 Gbps speed that it is suppose to be.  Is there a way to change the speed on switch port?  See attached screen shot from ruckus unleased admin login.  Also port 1 which does not have an ethernet cable connected to it show a warning status.  I tried resetting the port with no luck.
1 REPLY 1
Squozen
Contributor III
You likely have a bad cable. Try a different one and see if the 1gbps speed comes back.
