05-02-2025 12:58 PM - edited 05-02-2025 01:01 PM
A discussion in my office recently left me with some questions. I'm seeking guidance now. I've exclusively used manifest approach when code upgrading switches. I was told it do POE, code version, and boot (if needed for that model/code).
I'm hearing a few say that simply copying the image does all this as well. My gut reaction is that this is incorrect. I don't think Ruckus would include the POE firmware in the image AND put the raw files in the zip-folder, but I've been wrong before. I'm curious what Ruckus suggests as the best/preferred code upgrading method.
If it matters at all, we are primarily working with 7150 48ports
05-02-2025 02:22 PM
Our general recommendation is to use the single UFI image. This does indeed contain everything (OS image, boot code, POE firmware, etc.) in one file. You can use UFI starting with 8080. Hope this helps.
