10-28-2024 05:56 PM - edited 10-28-2024 05:57 PM
Hello. I also cannot get an ICX-7150 to sync with the time server.
This is my configuration:
SSH@xxx#sh run
Current configuration:
ver 08.0.95nT211
stack unit 1
module 1 icx7150-24-port-management-module
module 2 icx7150-2-copper-port-2g-module
module 3 icx7150-4-sfp-plus-port-40g-module
ntp
disable serve
peer 192.168.74.4
peer 192.168.74.6
peer 10.77.25.126
The clock is set to UTC, and is within 20 seconds of the actual time. When rebooting, this was the log entry:
Oct 29 00:45:48 informational NTP: The system clock is not synchronized and does not have a reference configured.
I have saved the config, and reloaded the switch. These are my association and status
SSH@xxx#sh ntp s
Clock is unsynchronized, no reference clock
NTP server mode is disabled, NTP client mode is enabled
NTP master mode is disabled, NTP master stratum is 8
NTP is not in panic mode
SSH@xxx#sh ntp a
address Domain name Reference Clock st when poll Reach delay offset disp
~ 192.168.74.4 None INIT 16 - 64 0 0.00 0.000 15937.
~ 192.168.74.6 None INIT 16 - 64 0 0.00 0.000 15937.
~ 10.77.25.126 None INIT 16 - 64 0 0.00 0.000 15937.
* synced, # selected, + candidate, - outlayer, x falseticker, ~ configured, **More characters in domain name
I have captures from the firewall it is directly connected to showing the ntp requests and the ntp replies, but the switch does not seem to be processing the ntp replies and setting the clock.
Any ideas?
10-29-2024 05:40 AM
Hi @timothy_harryma
Could you please let me know if this is a Lennar Home RUCKUS setup?
Please confirm.
Thank you again.
10-29-2024 05:40 AM
Hi @timothy_harryma
Please confirm.
Thank you again.
10-29-2024 08:19 AM
Sorry about that, it is not. Found the thread on Google Search, now I see it is for Lenna Home.
10-29-2024 10:01 AM
Hi @timothy_harryma
Thank you for your response and confirmation.
No problem at all. I’m assigning this case to an Enterprise Support Engineer for further assistance. They will respond to this thread as soon as they are available.
