07-26-2024 12:22 PM
I'm working on a ICX 7150 48zp and having a problem getting a tagged VLAN to co-exist with the default native VLAN 1 on a single interface.
When I add "vlan 10" > "tagged ethernet 1/1/1" the ethernet 1/1/1 is no longer part of vlan 1.
07-27-2024 03:31 AM
Hi Zif
Thank you for reaching us.
If you are not using port 1/1/1 in any other vlan as untagged then the port would still be a part of vlan 1 as untagged as vlan 1 is the default vlan on the switch.
Could you validate the details using below commands:
07-27-2024 06:22 AM
This is the only output I have right now. It definitely accepts only VLAN 10 after adding tagged ethernet 1/1/1 to the vlan 10 configuration section.
I even tried creating vlan 2 as a replacement and adding 1/1/1 as untagged but it would not allow me to set a port to set untagged to any port that has tagged VLANs assigned. It had a message that says something like "port ethe 1/1/1 are not member of default vlan". I read something that says it may need to be place in dual mode so I will be trying that soon
Port 1/1/1 is a member of 1 VLANs
VLANs 10
Untagged VLAN : 1
Tagged VLANs : 10
07-27-2024 10:43 AM
Hi Zif
Ack and Thanks for reaching us.
Dual mode is for older versions if you are running code 8080 and above I suppose you would be unable to see those commands.
If you want to "untagged port 1/1/1 to vlan 2" and earlier this port was in "vlan 1 as untagged" you can use the below commands
Could you let me know what is the firmware version running on the switch ?
