08-29-2024 02:41 AM
i enable port security on ports after connect a pc, the switch learn the mac address, set violation shutdown, i swap port interface to other pc it doesn't shut down
am i missing something?
09-02-2024 06:21 AM
Hello!
Can you please indicate the software version and share the config set on the port?
This info will help me understand why the switch is not behaving as expected. Thanks!
09-09-2024 12:28 AM - edited 09-12-2024 08:02 PM
ICX7150-24 Switch(config-port-security-mif-1/1/1-1/1/2)# sh ru int
interface ethernet 1/1/1
port security
violation shutdown
age 1440 absolute
secure-mac-address xxxx.xxxx.xxxx 1
interface ethernet 1/1/2
port security
violation shutdown
age 1440 absolute
secure-mac-address yyyy.yyyy.yyyy 1
interface Interface running-config section
ICX7150-24 Switch(config-port-security-mif-1/1/1-1/1/2)# sh ru interface
port security
violation shutdown
age 1440 absolute
port security
violation shutdown
age 1440 absolute
UNIT 1: compiled on Dec 16 2021 at 03:40:25 labeled as SPS08095f
(31457280 bytes) from Primary SPS08095f.bin (UFI)
SW: Version 08.0.95fT211
Compressed Primary Boot Code size = 786944, Version:10.1.21T225 (mnz10121)
Compiled on Wed Aug 25 06:27:49 2021
HW: Stackable ICX7150-24
UNIT 1: SL 1: ICX7150-24-4X1G 24-port Management Module
Serial #:FEG3232T245
Current License: 4X1G
UNIT 1: SL 3: ICX7150-4X10GF 4-port 40G Module
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
STACKID 1 system uptime is 17 minute(s) 8 second(s)
The system started at 03:40:47 GMT+00 Thu Dec 16 2021
it learned mac address, swapped port
still not even shut down
09-11-2024 11:46 AM
Thank you for your patience. The configuration appears correct. To clarify how port security violation shutdown works:
If port security is configured with the violation action set to "shutdown," the switch port will shut down if a security violation occurs. For example, if port 1 is configured to allow only a specific MAC address (say MAC 1), and you connect a different device (e.g., Computer 5) to port 1, the port will be shut down because the new MAC address does not match the allowed MAC address.
To address your concern, if you connect Computer 1 to port 2, port 2 will only shut down if it has already learned a different MAC address than the one currently being used by Computer 1. In other words, port 2 will shut down if Computer 1's MAC address is not on the list of allowed MAC addresses for that port, but this will not affect port 1.
In summary, a port will shut down only if a violation occurs on that specific port, not on other ports, unless those other ports also experience a security violation based on their own configuration.
I hope that is helpful, thanks!
09-12-2024 08:02 PM - edited 09-12-2024 08:03 PM
so if i set mac max to 1 will it shutdown?
