02-22-2022 06:24 AM
Hey Guys,
Appreciate this is an old switch and don't suspect anyone to spend much time helping me. I've got a C12 Brocade which I acquired some years back. I just use it for LAB purposes, however I noticed today I tried plugging in a test phone and it will not power via PoE (first 4 ports) I'm running the latest Image and Boot for this model.
See below output for port config and inline power. (Troubleshooting steps is rebooting switch, disable renabled of port, set PoE Class as 1 on the port as this is a Cisco phone. Also I have re-installed the PoE firmware.
interface ethernet 1/1/1
port-name PoE.Port
inline power power-by-class 1
interface ethernet 1/1/2
port-name PoE.Port
inline power
interface ethernet 1/1/3
port-name PoE.Port
inline power
interface ethernet 1/1/4
port-name PoE.Port
inline power
Test-Switch#show inl power
Power Capacity: Total is 68000 mWatts. Current Free is 68000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 On Off 0 0 n/a n/a 3 n/a
1/1/2 On Off 0 0 n/a n/a 3 n/a
1/1/3 On Off 0 0 n/a n/a 3 n/a
1/1/4 On Off 0 0 n/a n/a 3 n/a
Total 0 0
Test-Switch#sh inl power det
Power Supply Data On stack 1:
Power Supply Data:
Power Supply #1:
Max Curr: 1.2 Amps
Voltage: 54.0 Volts
Capacity: 68 Watts
POE Details Info. On Stack 1 :
General PoE Data:
Firmware
Version
02.3.9 Build 036
Cumulative Port State Data:
#Ports #Ports #Ports #Ports #Ports #Ports #Ports
Admin-On Admin-Off Oper-On Oper-Off Off-Denied Off-No-PD Off-Fault
4 0 0 4 0 4 0
Cumulative Port Power Data:
#Ports #Ports #Ports Power Power
Pri: 1 Pri: 2 Pri: 3 Consumption Allocation
0 0 4 0.0 W 0.0 W
Thanks,
Chris
