10-06-2021 03:04 AM
hello community
i have an issue with POE firmware on my ICX-7150-ZP48.
I've upgraded the switch to version SPS08095d using UFI file.
the switch was upgraded and using the 08095d image,
but the POE firmware isn't installed.
"sh inline power details" output shows that the firmware ver is 00.0.0 and the HW ver is unknown.
SSH@ICX7150-48ZP Switch#sh inline power detail
Power Supply Data On unit 1:
++++++++++++++++++Power Supply Data:
++++++++++++++++++Power Supply #1:
Max Curr: 16.6 Amps
Voltage: 55.3 Volts
Capacity: 920 Watts
PoePower: 740 Watts
power supply 2 is not present
POE Details Info. On Unit 1 :
General PoE Data:
+++++++++++++++++Firmware
Version
00.0.0Hardware
Version
UNKNOWNDevice HW version : 0:UNKNOWN 1:UNKNOWN 2:UNKNOWN 3:UNKNOWN 4:UNKNOWN 5:UNKNOWN 6:UNKNOWN 7:UNKNOWN
Device Temperature(deg-C) : 0:0 1:0 2:0 3:0 4:0 5:0 6:0 7:0
Device Status : 0:Failed 1:Failed 2:Failed 3:Failed 4:Failed 5:Failed 6:Failed 7:FailedCumulative Port State Data:
+++++++++++++++++++++++++++#Ports #Ports #Ports #Ports #Ports #Ports #Ports
Admin-On Admin-Off Oper-On Oper-Off Off-Denied Off-No-PD Off-Fault
-------------------------------------------------------------------------Cumulative Port Power Data:
+++++++++++++++++++++++++++#Ports #Ports #Ports Power Power
Pri: 1 Pri: 2 Pri: 3 Consumption Allocation
i tried to install the POE firmware manually but with no success.
the process is stack and I get the below log messages, saying that the communication with the PoE controller is lost.
I've tried both icx7xxx_poe_02.1.8.b004.fw and icx7xxx_poe_02.1.0.b002.fw.
any idea what it means?
any suggestions and tip are appriciate.
thanks
May 21 04:52:02:I:System: Stack unit 1 POE Power supply 1 with 740000 mwatts capacity is up
Dynamic Log Buffer (4000 lines):
May 21 22:16:41:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:16:17:I:MGMT Agent: Failed to connect to network controller at 54.243.80.60 Error: HTTP Response Code 401 Reason: Switch registration status is pending
May 21 22:15:40:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:14:39:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:13:38:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:12:37:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:11:36:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:11:15:I:MGMT Agent: Failed to connect to network controller at 54.243.80.60 Error: HTTP Response Code 401 Reason: Switch registration status is pending
May 21 22:10:36:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:09:35:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:08:34:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
May 21 22:07:33:C:System: PoE Severe Error: Lost communication link with the PoE controller on unit 1 in slot 1. Shutting down and restarting the PoE module to recover.
--More--, next page: Space, next line: Return key, quit: Control-c^C
SSH@ICX7150-48ZP Switch#sh poe emesgLog Size: 2000 entries. Number of entries in use: 1035 for unit 1.
Log printing is requested for complete log.
|S.No.|Timestamp | Sys | Dev | Port | Event Trace Message |
1 | Fri May 21 04:52:02 | N | N/A | N/A | PoE Event Log Mgr: User Req Logging On
2 | Fri May 21 04:52:04 | Y | N/A | N/A | Controller reset was detected unexpectedly du
3 | Fri May 21 04:52:59 | Y | N/A | N/A | Loss of sync with controller in slot 1
4 | Fri May 21 04:54:00 | Y | N/A | N/A | Loss of sync with controller in slot 1
5 | Fri May 21 04:55:01 | Y | N/A | N/A | Loss of sync with controller in slot 1
6 | Fri May 21 04:56:02 | Y | N/A | N/A | Loss of sync with controller in slot 1
7 | Fri May 21 04:57:03 | Y | N/A | N/A | Loss of sync with controller in slot 1
8 | Fri May 21 04:58:01 | Y | N/A | N/A | FW DL...DL Cmd Err, Aborting
9 | Fri May 21 04:59:03 | Y | N/A | N/A | Loss of sync with controller in slot 1
10 | Fri May 21 05:00:04 | Y | N/A | N/A | Loss of sync with controller in slot 1
11 | Fri May 21 05:01:05 | Y | N/A | N/A | Loss of sync with controller in slot 1
12 | Fri May 21 05:02:05 | Y | N/A | N/A | Loss of sync with controller in slot 1
13 | Fri May 21 05:03:06 | Y | N/A | N/A | Loss of sync with controller in slot 1
14 | Fri May 21 05:04:07 | Y | N/A | N/A | Loss of sync with controller in slot 1
15 | Fri May 21 05:05:08 | Y | N/A | N/A | Loss of sync with controller in slot 1
16 | Fri May 21 05:06:09 | Y | N/A | N/A | Loss of sync with controller in slot 1
17 | Fri May 21 05:07:10 | Y | N/A | N/A | Loss of sync with controller in slot 1
18 | Fri May 21 05:08:11 | Y | N/A | N/A | Loss of sync with controller in slot 1
19 | Fri May 21 05:09:12 | Y | N/A | N/A | Loss of sync with controller in slot 1
20 | Fri May 21 05:10:13 | Y | N/A | N/A | Loss of sync with controller in slot 1
21 | Fri May 21 05:11:14 | Y | N/A | N/A | Loss of sync with controller in slot 1
22 | Fri May 21 05:12:14 | Y | N/A | N/A | Loss of sync with controller in slot 1
23 | Fri May 21 05:13:15 | Y | N/A | N/A | Loss of sync with controller in slot 1
24 | Fri May 21 05:14:16 | Y | N/A | N/A | Loss of sync with controller in slot 1
25 | Fri May 21 04:52:02 | N | N/A | N/A | PoE Event Log Mgr: User Req Logging On
26 | Fri May 21 04:52:04 | Y | N/A | N/A | Controller reset was detected unexpectedly du
27 | Fri May 21 04:52:59 | Y | N/A | N/A | Loss of sync with controller in slot 1
28 | Fri May 21 04:54:00 | Y | N/A | N/A | Loss of sync with controller in slot 1
29 | Fri May 21 04:55:01 | Y | N/A | N/A | Loss of sync with controller in slot 1
