Need help finding the sps08091 bin file
mike_neubauer
Need help finding the sps08091 bin file. I've looked through the downloads and I can't locate it.
12 REPLIES 12
Correct, will not reboot or go down
BenBeck
Correct, 'copy flash flash secondary' will copy the primary image to secondary flash. The switch function will not be interrupted during this copy. Once finished, you can issue 'show flash' to check the secondary image.
mike_neubauer
Thank you! I will give it a try.
mike_neubauer
I just did that command and I received a message that the MDF went offline and then received one that it was online. I don't see ping coming through now from the dashboard. Is this normal?
mike_neubauer
Any idea why this may have happened?
