My primary and secondary flash was erased during an attempt to update the
image. My CLI is showing: ICX64XX-boot>>.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-02-2018 04:43 AM
My primary and secondary flash was erased during an attempt to update the image. My CLI is showing: ICX64XX-boot>>. I can ping to and from my PC which I am using as ymy TFTP server. I loaded the latest firmware files on to my PC. I have them sitting in C:\image I set the env image_name to image/ICX64S08030r.bin. this is the image i am trying to load. I just get %Ts and then the session errors out. what am I missing?
27 REPLIES 27
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-02-2018 05:44 AM
Right when it prompts you and starts counting down...
Enter 'b' to stop at boot monitor...
From there do your recovery like mentioned above.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-02-2018 05:47 AM
When I press b it just brings the following:
ICX64XX-boot>>
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-02-2018 05:48 AM
and then stops
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-02-2018 05:51 AM
Right... you need to recover as described above. This is where you enter those recovery commands... All those options mentioned in my first post should be available - specifically:
ICX64XX-boot>> ?
? - alias for 'help'
boot - boot default, i.e., run 'bootcmd'
boot_primary - primary boot; boot from primary partition
boot_secondary - secondary boot; boot from secondary partition
cp - memory copy
eeprom - EEPROM dump or program command
help - print online help
i2cprobe - Get special i2c device id
md - memory display
memtest - To perform DDR memory test
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
reset - Perform RESET of the CPU
saveenv - save environment variables to persistent storage
setenv - set environment variables
sflash - read, write or erase the external SPI Flash.
tftpboot- boot image via network using TFTP protocol
update_primary - primary update; update primary partition
update_secondary - secondary update; update secondary partition
update_uboot - get the uboot image over tftp.
version - print monitor version
Looks like everything you need is at your firngertips
ICX64XX-boot>> ?
cp - memory copy
md - memory display
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-02-2018 05:52 AM
from here I entered
setenv ipaddr 10.20.1.3
setenv netmask 255.255.255.0
setenv gatewayip 10.20.1.1
setenv uboot 10.20.1.2
saveenv
ping 10.20.1.2
Provide the name and path
setenv image_name image/ICX64S08030s.bin
update_primary
saveenv
ping 10.20.1.2
update_primary
