06-10-2021 04:46 AM
I installed l3-prem-2X10G license but my ICX 7250 does not have L3 features. What could be the problem? I reloaded the switch but it is has l2 features, not L3.
ICX7250-48 Switch#show version
UNIT 1: compiled on Jan 5 2021 at 21:06:08 labeled as SPS08090j
(29360128 bytes) from Primary SPS08090j.bin (UFI)
SW: Version 08.0.90jT211
Compressed Primary Boot Code size = 786944, Version:10.1.18T215 (spz10118)
Compiled on Mon Jul 13 08:53:15 2020
HW: Stackable ICX7250-48
UNIT 1: SL 1: ICX7250-48 48-port Management Module
Serial #:DUJ3--------
Software Package: BASE_SOFT_PACKAGE (LID: fwlIHGIuFFn)
Current License: l3-prem-2X10G
P-ASIC 0: type B344, rev 01 Chip BCM56344_A0
06-10-2021 04:50 AM
Your booting from switch code.
check your flash and if you have SPR as secondary,
run
”boot system flash secondary yes”
this will instantly reboot the switch, make sure this is lab only.
06-11-2021 11:14 AM
Thanks Corey,
That was the right.
Best Regards
Hashim
06-14-2021 04:05 AM
Thanks a lot.
