05-02-2024 12:47 AM - edited 05-02-2024 12:58 AM
Hello everybody,
I have a problem when a try to add a new unit in an existing stack of ICX7150. (08095F)
Of course, the active stack and the unit have the same version.
The stack mount well, but the active controller request a reboot of my new unit everytime the stack mount.
I have try to add with static and dynamic methods.
Here the logs of my issue :
____________________ ON ACTIVE CONTROLLER_________________
SSH@SW_EMERAUDE_253#sh stack
T=3h30m53.1: alone: standalone, 😧 dynamic cfg, S: static
ID Type Role Mac Address Pri State Comment
1 S ICX7150-48PF active fc5c.4532.3988 200 local Ready
2 S ICX7150-48 standby 3845.3b2f.5238 190 remote Ready
3 D ICX7150-48P member 903a.7216.d3a8 0 remote Reset: vlan: U1 1024, U3 4
active standby
-3/3| 1 |3/1--3/3| 2 |3/1--3/3| 3 |3/1-
Will assign standby in 78 sec due to election
Standby u2 - protocols ready, can failover
Current stack management MAC is fc5c.4532.3988
_______________________ON NEW UNIT (CLI)_________________________________________
Success - Enable stacking. This unit actively participates in stacking
RSA Key pair is successfully created
[MEMBER]local-3@ICX7150-48P Switch>
PS 1, Internal Power supply detected.
PS 1, Internal Power supply is up.
PoE: Stack unit 3 PS 1, Internal Power supply with 370000 mwatts capacity is up
Creating certificate, please wait...
SSL Client Certificate is successfully created
UNIT3:System initialization completed...console going online.
UNIT 3: compiled on Dec 16 2021 at 03:40:25 labeled as SPS08095f
(31457280 bytes) from Primary SPS08095f.bin (UFI)
SW: Version 08.0.95fT211
Compressed Primary Boot Code size = 786944, Version:10.1.21T225 (mnz10121)
Compiled on Wed Aug 25 06:27:49 2021
HW: Stackable ICX7150-48-POE
UNIT 3: SL 1: ICX7150-48P-2X10G_2X1G POE 48-port Management Module
Serial #:
Current License: 2X10G
P-ASIC 4: type B160, rev 11 Chip BCM56160_B0
UNIT 3: SL 2: ICX7150-2X1GC 2-port 2G Module
UNIT 3: SL 3: ICX7150-4X10GF 4-port 40G Module
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
STACKID 3 system uptime is 25 second(s)
The system started at 03:54:57 GMT+00 Thu Dec 16 2021
The system : started=warm start reloaded=by "reload"
My stack unit ID = 3, bootup role = member
[MEMBER]local-3@ICX7150-48P Switch>UNIT3:In szAgent_save_initial_runningConfigTimestamp(), 0
T=32.0: Election, I 903a.7216.d3a8 was member, no change, ID=3, pri=0, 3U(1-3), A=u1, nbr#=2 2,reason: u2: port-up,
T=34.9: Election, I 903a.7216.d3a8 was member, no change, ID=3, pri=0, 3U(1-3), A=u1, nbr#=2 2,reason: u1: stk-po-chg,
T=38.4: Boot request from u1 mac=fc5c.4532.3988, my ID=3, reason: vlan: U1 1024, U3 4, flash: Primary, jumbo=0,
_______________________________________________________________________________________
Has somenone knowledge of this issue ? I've try some technics but this issues occur everytime.
Thank you very much. Kevin
